Results 1 to 10 of 12
Thread: cam and thermostat question
    Metairie, Louisiana
    I think my friend is going to buy me a shortened ls2 cam for christmas.
    I know some people are going to say get a different cam but ive seen the truck its coming out of and i like the easy lope. It still sounds very good. Very good power for a stock cam.
    The question is am i going to have to get longer pushrods?
    The question about a thermostat is..
    What do people recommend if i was keeping my clutched fan for a while.
    180 or 160?
    Where can i get either?
    And how do it get it out of the water neck or is there special one i have to buy?
    This isnt in the thread title
    But what is a nice intake manifold for a good price?
    i dont care if its polished or anything i just want something that will give a nice horsepower gain, good priced, but is also generally a quality part.
    I'd actually like to find a ls2 or ls6 intake manifold.
    oakland twp, MI - presently India on business
    What motor do you have? and i wouldn't bother swapping out your intake, stock ones are good for a lot of HP
    99 Chevy 2500 LQ4/4L80E mostly stock...
    99 KTM 250 SX
    00 GSXR 600
    02 Honda 50
    08 YZF R6
    Its a truck thing, you jeep fags wouldn't understand
    www.fquick.com/wastedrubber
    ff_jeff Guest
    Leave the stock thermostat in, until you get efans. You wont see any cooler temps unless the fans come on sooner.
    +1 on not getting a new intake manifold. You wont need it for a while.
    What are the specs on the cam? Honestly If you have the money for a new intake manifold, then I would get a little more agressive cam. Depending on what your year and engine size is, you may want to save some cash and get a 6.0 or a Ls motor. If I could do it again, I would have bought a 6.0 and modded it, But good news is the parts can transfer over. Headers ORY an a cood cold air intake will compliment the cam well, with a Nelson Performance tune... >>> Nelson Performance - Performance without Sacrificing Drivability <<<<
    Metairie, Louisiana
    I donn't know the specs on the cam, all i know is it's a stock ls2 cam shortened to fit a 5.3.
    I have an intake magnaflow exhaust tb spacer and LSD unit.
    All I plan on addidng to a motor with 140,000 with a transmission that has less then 40 grand to go is...
    ls2 cam
    thermostat
    electric fans
    and pulleys
    and maybe a tune
    All depends if my tranny goes out anytime soon.
    But my question still remains how do you get that thermostat out of the waterneck. I tried already on a new one. Its a biiiittttcccch
    Getting the stat out is easy, drain coolant, remove lower hose from water pump end, remove two 10mm bolts holding the stat housing in place, remove cover and then thermostat. If your's is built into the cover then the stat will come out with it. You replace the housing and stat at the same time. Thats how my fbody pumps are, one piece stat with housing.
    ff_jeff Guest
    Quote Originally Posted by Nola327 View Post
    ls2 cam
    thermostat
    electric fans
    and pulleys
    and maybe a tune
    What year is the truck? If its older,pre-2003, the thermostat doesnt come out. The whole housing is replaced. 04 and up the thermostat pops out of the housing. I didnt drain All my coolant, I just removd the 2 bolts, had a bucket under to catch coolant, and swapped them out. However much coolant drained, I replaced.
    Yep. The 03's and earlier are one piece UNLESS the water pump has been replaced. The new truck pumps are new style even for 1999-2003 models. Good thing too....all I had to do was buy a $200 to save $35 on my tstat...LOL
    Get the tune and fans 1st.
    Metairie, Louisiana
    well its a 2000 and I know its a one peice.
    Where do i go about getting the housing to hold that, I really have to get a newer stle water pump in order to get a lower temperature t-stat
    AEM Brute Force Intake~PowerAid TB Spacer~Hypertec Programmer~Detroit TruTrac 3.73~Magnaflow 1in2out side exit~06 Tahoe 20's~Reflexxion Steel Cowl Hood~2" Rear Shackles~160 t-stat
    Soon to come:
    LS2 cam~LS6 intake manifold~Pulleys~90mm TB~E-Fans~2-4 drop~SS Spoiler~Front Spoiler~Smoked and haloed tails~Denali headlights with amber halos
    www.aacstyle.com
    ^^^for custom headlights and tailights
    If it still has the old style tstat with the outlet on it you'll need to buy the $45-60 lower temp tstat that also comes with the housing.
    Nov 2006
    Mesquite, TX
    you cant use an LS2 cam in the 5.3 anyways....LS2's cam sensor is at the front on the timing chain cover it reads off the timing chain gear on a 5.3 the cam sensor is at the back of the motor and reads off the cam itself...i will try and get you pics of the 2 later when i get home
