Results 1 to 10 of 12
Thread: What trans. lines for 5.3/60e in a obs
    Spiro, Oklahoma
    What did you guys use for transmission cooler lines? is there a part number for a set that will work or will a set have to be made up? thanks
    I think I saw a braided set on CKPerformance.com with all fittings for $120?
    Nope, it was Bowlertransmissions.com for $130.
    Spiro, Oklahoma
    Those look nice but kind of expensive. What do most people use on their swaps? Would it work if I cut the ends of my old lines and ran rubber hose?
    I do that when I have to. I used the stock lines and put short pieces of rubber fuel or tranmission quality hose on mine, to join where the new lines are layed out.
    Yep, Red's right. Make sure the hose you use is ATF friendly. Regular hose will turn to mush and leak after a while.
    Spiro, Oklahoma
    be sure to measure the stuff you have now. The factory 2000 model Tahoe hoses I just finished working with were 3/8".
    Hurley, Mississippi
    My new lines were 3/8" and the old ones were 5/16". So I went to the local auto parts store and picked up so 3/8 to 5/16 flared reducers, worked great.
    '86 Silvy- '06 6.0/4L80E, K&N, 2.5 X-pipe Magnaflows, 20" Foose Wheels, Auburn Pro, 3.90 Richmond Gears, and the list is growing!!!
    Aug 2006
    I cut my hard lines on my 80 right after first curve out of tranny, put on an compression fittings, ran -6 hose to the cooler up front.
    86 C10 6.0/4l80e
