Results 1 to 10 of 10
Thread: What do you think of this cam??
    Will this cam work in my truck??
    Voodoo Hyd Roller Cam - LS1 LS2 282/288 - Lunati Power
    Would you recommend going with something of that size.
    Advertised Duration (Int/Exh): 282/288
    Duration @ .050 (Int/Exh): 232/238
    Gross Valve Lift (Int/Exh): .599/.601
    LSA/ICL: 113/109
    Valve Lash (Int/Exh): Hyd/Hyd
    RPM Range: 2400-6800
    Racoon Twp., PA
    Lot of extras required, besides springs and pushrods. Probably would sound nasty tho!
    2013 CC 5.3
    81 C10 LS1 project
    Yeah it would sound nasty. A buddy of mine has one a little bit bigger than this. Just called him and found that out.
    Racoon Twp., PA
    Would love to do a cam in the lil 4.8, but $ is a lil on the low side right no. Plus i wanna do one that isn't gonna kill the low end.
    2013 CC 5.3
    81 C10 LS1 project
    Talking
    well, all of the runs that i mainly do are higher in the RPM range, so this would work out for me. N i figure, if im going to do a run from a dig, by the time i hit 2400rpm, that honda wont know what hit him.
    Racoon Twp., PA
    Yeah, don't race, but always run in a lower gear, especially after the longtubes, right around 3K and up it sounds mean....and makes your ears bleed. Have one of the flowmasters thats 6 inches long, so it does chit. Magnaflow with a cutout when money available.
    2013 CC 5.3
    81 C10 LS1 project
    Sep 2006
    THE 405
    That's the cam I'm fixin to put in my truck!
    midweststreetcars.com
    Mar 2007
    Newark, Delaware
    A nice cam--and work well in your truck. You definitely need at least a 3000 stall or higher with it. PRC springs and hardened pushrods are a must with that cam. I say do it!!!!
    thats an awesome cam!!specially in a RSCB if you have the supporting heads, tranny, stall = 4ktriple disc, heads and such that bish is gonna move, you wont loose much lowend niether..
    got a 3800 stall if interested pm me, by the way that in a 6.0?
    Simple: 408 on steroids!
    single digits coming soon!
