Real quick...1994 3/4 ton suburban with 2001 6.0 (LQ4) and matching 4l80e.
Anyone had any problem with their 4l80e not shifting? When its in OD and D it wont get out of first gear. It was shifting ok, but just started doing this. Anything come to mind?
Fuel gauge is pegged past full. I never touched the signal wire so I dont know why it wouldnt work. Switched out the fuel pump to AC Delco, but made all connections. Maybe ground?
When i make the tach signal connection it doesnt look like I am getting the full signal. Seems to be about 500-1000 below where it should be.
