Alrighty guys...I will get down to it...
Driving down the road at 60mph. No noise whatsoever, the engine revs a bit then nothing, no gears at all, just like someone had bumped the truck into N. Engine running no howl, no noise at all.
If I put it into Park while Engine is running, it makes a rachetting noise. If I start the truck in Park, NO rachetting noise.
Makes no difference if in 2H or 4, still no gears...
No fluid on the ground, and tranny fluid is up and clean, not burnt. Haven't checked the T-case fluid yet (tonight, I just got the truck home last night).
Rear end and drive shaft are good.
Electronic 4wd (2H 4H 4L buttons). 2003 GMC 2500HD, 6.0L Automatic (not the allison) 4x4.
This tidbit may be unrelated, but prior to this, the 4wd wouldn't engage unless you came to a stop first. That happened after the Mrs. decided to get it stuck and go for a little off road...
Thinking it is the T-case. Is there anything simple to check to make sure it isn't the electronic portion first before I drop the T-case out???
Any help or thoughts would be appreciated... Thanks guys![]()
