Results 1 to 10 of 12
Thread: Larger oil filter
    May 2004
    Larger oil filter
    I haven't posted this in a while but I wanted to remind everyone that's completed an LS1 swap you can use the Wix 51522 oil filter which is about 1 1/4" longer than a stock filter. You'll get more surface area with this filter and maybe a little longer oil life. I used to use ACDelco but I haven't been able to find the longer filter anymore.
    97 GMC, 2002 LS6.
    1991 GMC Syclone #1428
    SE Georgia
    Does this work on the 5.3's too?
    Tired ol' 5.7, 5.3 swap in progress
    Handle every stressful situation like a dog.
    If you can't eat it or hump it.
    Piss on it and walk away.
    May 2004
    Yes it will. The ACDelco PF-46 is the smaller one but they both fit. Fram and Bosch both have a long filter but I've always been partial to Wix since years ago Fram used to hold the filter element together with a piece of string. They don't anymore though, most filters are built pretty sturdy these days with metal casings. You only need to worry about the how many microns the paper is or how cheap the paper is. If you change your oil regular I wouldn't worry about it.
    97 GMC, 2002 LS6.
    ....I agree just don't use a WIX fuel filter on a DMax.
    NW South Dakota
    Quote Originally Posted by NITROUS View Post
    PF61 is the new AC Delco# for the longer filter now.
    May 2004
    The problem with the PF61 is it doesn't have the anti drain back valve in it like the Wix, It is a longer filter though.
    97 GMC, 2002 LS6.
    NW South Dakota
    The PF59 is long also...does it have a drainback valve???
    The 61 replaced the 58. Not sure the 59 is the same.
    Missoula,Montana
    What about the Mobil One M1-206?
    '00 1/2 TON ECSB 5.3L 4L60E
    K&N Filter,Gibson Exhaust,Superchips Programmer,Billet Servos,'03+ Taillights,White Door Handles,Carbon Metallic Grille Emblem,6000K HID'S
    That's the filter I use. Mobil 1
