I have a 1998 Silverado extended cab short bed. I have the motor (5.3 out of a 2003) in the truck with the factory 4L60E. My question is did any of you that have completed this swap have to lengthen or shorten the drive shaft?
Josh
Josh
driveshaft was fine. If your going with the 03 make sure the gas pedal, TAC module, and PCM are from the same vehicle.
1996 GMC extended cab, 2003 5.3/auto
I had to move my transmission crossmember up one hole on the passenger side but other than that the drive shaft should be fine.
97 GMC, 2002 LS6.
1991 GMC Syclone #1428
what about the driveshaft out of my 1990 5.7/700r4 that is now going to be a 6.0/4l80? will it have to be altered?
Tired ol' 5.7, 5.3 swap in progressHandle every stressful situation like a dog.If you can't eat it or hump it.Piss on it and walk away.
