Results 1 to 10 of 11
Thread: chmsl supply voltage/stop lamp supply voltage
    Kentucky
    On nelson wiring harness the wire labels "chmsl supply voltage/stop lamp supply voltage" what does this go to? I'm assuming it something to hookup for the cruise.
    1996 GMC extended cab, 2003 5.3/auto
    Quote Originally Posted by 468Blazer View Post
    this is what i got from google:
    Center High Mounted Stop Lamps (CHMSL)
    Simple: 408 on steroids!
    single digits coming soon!
    CHMSL = the stop light at the back top of the cab
    LSX conversions, so easy a caveman can do it.
    In the OEM application it goes to the output side of the brake lamp switch on the pedal but someone from NP should probably answer this question.
    I thought it was for the torque converter clutch, wire is powered with key on but no power when the brake pedal is pushed.
    They did, the response was "dont know"
    There are two main outputs from the switch. It's one of the two mentioned above.
    You're kidding.
    Wow.
    At least my NP fan harness fit like it should....mostly.
    Once again, I might suck at this conversion stuff (for many reasons) but I might be able to help if I knew what you were working on.
    03 5.3 to 96 gmc
    BRAKE 10A circuit 440 goes from the switch to the PCM (for cruise and TCC) as well as EBCM and clutch start switch (if equipped). CHMSL circuits 17 and 1620 connect the CHMSL lamp and the stop lamp switch to the flasher module (because the CHMSL does not flash with signals or have to light up dimly for park lights like the LH and RH lamps). STOP circuit 1320 connects the flasher to the rear lamps.
    None of that probably helps.
