Originally Posted by
r6z4o6
get a ls1 t56 or you'll be in for even more converting!
ditto i ran a t-56 out of a z28 camaro which was an ls1. if you dont get one off an ls1 you will have to get a different bell housing to mount it to the motor the ls1 bellhousing is a direct fit. i also bought the ls7 clutch and upgraded gm slave for the 01 and 02 camaros. as far as the drive shaft goes. i used a drive shaft from a short bed reg cab 1998 4.3 auto with the 4l60e tranny because the shaft was a perfect fit in the transmission aswell as perfect lenght. i found this out the hard way though... i cut my stock driveshaft and changed the yoke but my truck was a 5 speed so its different from the autos. good luck with the swap! it was well worth it for me!
oh and if you plan on going the t-56 route plan to spend some $$$ i paid 1350 for the tranny 400 for the clutch,flywheel,and pressure plate, 150 for the slave, 120 for the short throw hurst shifter, just a heads up
