Results 1 to 10 of 21
Thread: Which 6.0 should i buy?
    I'm hoping some of you guys can help me out. I have a 1999 ecsb with a 4.8 thats about to turn into a grenade! So im gonna do a 6.0 and have have a couple local to choose from but im not sure what year i should be looking for. Any help on which direction i should go would be great.
    at my house
    Quote Originally Posted by Silverado889 View Post
    99-02 is DBC which will be compatible with your current setup.
    03-0x will DBW which you will have to purchase the Tac module and pedal for DBW
    05-0x you would have to make provisions for Efans since those motors will not have a mechanical fan
    If it was me, I would reuse my old harness and throtle body (if going with 03 and newer) and it will be easy as cake
    DFW, TX
    Shortbloack? Longblock?
    LQ4, LQ9, LS2......
    need more info......
    "old age and treachery will always overcome youth and ambition"
    author unknown
    Lq9 has higher compression (flat top pistons) and only likes high octane fuel. The LQ9 can be found under the hoods of Vmax's and SSS's.
    The LQ4 is an almost identical truck motor with lower compression (it has dished pistons). Its used in 2500's and will run on low octane. Imo, unless you are going to run a considerable cam the LQ4 is the best bet.
    Quote Originally Posted by jtaliaferro View Post
    So you think going with an 03-04 lq4 is the way to go? its not a daily driver so i will be putting a healthy cam, LT's, etc in. I just dont want to get a motor that has is going to be a pain versus a year newer that will almost drop rite in. Thanks
    at my house
    With your harness, throttle body and computer it will be a direct replacement.
    2003 Silverado RCSB
    LQ9 6.0l, PS longtube, CAI, E-Fans and a custom tune via hptuners
    i have a 99 ecsb that had a 4.3 now have a 04 lq9 (excalade) dbc since you have a 4.8 dbc youre good to go, not much more needed except for a tune... all your accessaries will bolt up. even intake.
    Simple: 408 on steroids!
    single digits coming soon!
    Quote Originally Posted by skeet View Post
    Well I guess i'm on the hunt for a 03-04 lq4 or lq9 then. Of course the three 6.0 engines that are local are 01-02. I can get one for $700, is it worth the hassle or do i wait it out for a 03-04. Thanks guys I really appreciate the help!
    Mar 2006
    Phoenix, AZ
    I'd get an 05+ LQ4 if you can. The 05 and up motors have the stronger LS2 style rods and timing chain. If not, any 01+ LQ4 would be fine as long as it wasn't abused.
    None of this matters....he can reuse his original accessories, throttle body, intake manifold, etc and not have compatibility issues.
    2006 GTO M6 Brazen Orange
    2006 Silverado CCSB Duramax
    Quote Originally Posted by thunder550 View Post
    Thanks! One more question. I can't find an lq9 anywhere around here (NH), but i found 2 04 lq4's. One for $1250 with 61,000 and 1 for $1150 with a little more mileage. Does this sound about rite? If it does i'll pick it up tomorrow. then i'll be ready cam and tune suggestions. Thanks again!
