New to the board. I have a 1972 GMC swb 2wd and recently purchased a 2002 6.0L 4L80 combo out of a wrecked 2500hd 2wd. Wondering if anyone has done a similar swap? Looking for someone to give pointers, etc.
gmcgrands@aol.com
Mark
gmcgrands@aol.com
Mark
1972 GMC Sierra Grande SWB 2WD 6.0 liter Gen 3, 4L80E, Fatman stage 5 IFS Under construction
Mark
Hey nice to see you here. I have an '81 with a 5.7L LS1. I think the frame is very similer (if not the same) as mine. I'd be glad to give pointers if you need some.
That's gonna be one badass setup, these engine run forever and like the nos heheh.
Are you going to use the stock HD harness or make one?
later,
allen
Nelson Performance
FastestTruckList.com
NP on Facebook
Youtube Channel
Farmtruc I have the stock harness, computer, maf, etc, but I think it might be easier with a aftermarket harness. I talked with Painless last week and there in the final stages of testing before they release one. Im doing a frame off on the truck and have the time to wait. Im working on the suspension componets and the bare frame right now. I have this same combo in my daily driver (2002 1500HD 4x4 crew cab. Just wantint to gather any suggestions or pointers for when I get to that point.
GMCWANTSLS1 I will probably have questions when I get closer. Any suggestions on anything to prepare for or purchase in advance?
Anyone else done anything similar? Anyone transplant a 6.0L and a 4Ll80?
Mark
I was going to perform a similar conversion on my 70 gmc and decided to back off of it for now. What I learned is that the exhaust won't fit in the frame without either cutting the frame, or finding another exhaust setup. Headers or corvette manifolds will work. The A/C compressor will need to be swapped out as it will not work with the older expansion valve setup. Naturally, you'll have to install a fuel pump, and rig some sort of spedo cable if you are going to use the original gauges.
I'm looking forward to seeing what you come up with. My frame-off budget just wouldn't let me do the full 5.3L upgrade, so I'm going to put my 383 back in with a 200R4. At least this way I'll have overdrive.
Oh yeah, I forgot to say that for the newer transmission to fit, you'll have to drill new tranny crossmember holes in the frame. They will need to be 1.75" back from the 350 turbo mounting holes.
You can get a Cable X from Abbott Industries for the speedo.About $300 bucks.Real easy to install.
