Results 1 to 6 of 6
Thread: lost 1st and overdrive Saturday
    Trans was acting up, and wouldn't lockup or shift in to 4th. When I exit the highway the truck wouldn't go into first. Wen't out Sunday morning and the trans shifted fine. I hate to say it but I thinkI am going to have to get another @#$%^& converter! Looks like I am going to go with the yank like I should have in the first place.
    2002 ecsb
    LS1
    JPR stage I heads
    218/224 529/536
    AS&M Headers
    Volant, Magnaflow Dual/Dual
    SSF 3500 4.10
    East Coast
    That sucks ass man.. hopefully its not the tranny screwing up on you.. let us know how it goes after the yank is installed. Which yank are you going to go with?
    91 s10 - bagged and bodydropped...getting rebuilt
    91 nissan - backhalfed and bagged
    turns out the shift solinoid had some type of material blocking it so it wouldn't shift. Probably some clutch material. The fluid is still red and doesn't smell burnt. I am going to have the trans back flused and see what comes out.
    2002 ecsb
    LS1
    JPR stage I heads
    218/224 529/536
    AS&M Headers
    SSF 3500 4.10
    East Coast
    w3rd, glad nothing major was wrong with it. Hopefully its fixed.
    Sterling, VA
    You still should have got the yank! I hope your trans holds together. You may have to go easy on it for a while. Good luck.
    1991 Formula Firebird
    2001 LS1/4L60E, 3.23 posi rear
    Comp XE 216/216 .577/.577 114LSA cam
    918 Springs, hardened pushrods
    Yank SS3600 torque converter
    PCM reprogrammed for cam and converter
    3" exhaust
    BRM Adjustable torque arm, tubular read LCAs
    Spohn Adjustable panhard bar, front steering brace
    Spohn Subframe Connectors
    4th Gen style wheels
    Bilsteins sport struts and shocks
    San Antonio, TX
    hey, go get that stock trans built, get a shift kit and the server, before it's too late, doh
