Results 1 to 6 of 6
Thread: Underdrive Pulley
    Any of yall ever done an underdrive pulley? A buddy of mine did it on his Stang and he picked up some power. I'm not planning on running a big system through this thing. A single Apline Type R 12 at most. What do yall think? Any links to site's that sell them? Any tips on installing one? Thanks for the help.
    2000 GMC 4.3L 2wd Auto Reg Stepside
    Performance: Volant Cold Air, Flowmaster Duals, Powerraid Throttle Body Spacer, Derale 18" Electric Fan, 180* T-stat, Underdrive pulley coming soon
    Exterior: 3" Body Lift, 31" tires
    Interior: Full painted interior (and I mean EVERYTHING except the cloth)
    Anyone?
    Dec 2003
    Orange Park, FL
    well since no one with some experience has answered your question. ill try and help...
    I've heard of 8-12rwhp gains with the pulley. There are tons of sites that sell them. maybe try Tbyrne
    2000 5.3L A4
    Fuddle 2800 + CF 100 jet + HP Tuners
    ETstreets + Dual cut outs + KP 4 link
    http://memimage.cardomain.net/member.../496250_63.jpg
    Thanks a lot for the help.
    Jasper, Ga.
    I got my underdrive pulleys from Tbyrne. Came with belt and instructions. I had a friend do mine. He need a differant pulley puller to get it off, but with the right tool it came off fine. Make sure you get the pulley for the alterantor also. At lights volts are low but run on up to 14 on the gas.
    1999 Silverado 1500 Ext. cab Red 2/4 hotchkis drop & swaybars, bilstein stocks, AR626 & 404 Nitto's, Yank converter, ASM headers, ASP underdrive pulley, Taylor wires , free mods VCN 2000, Nelson Performance tuning
    2002 Red WS6 M6; Flow master K&N
    I bought an underdrive pulley from TByrne. $250 or so. It made the truck accelerate all the way to the 5800RPM line, before it felt like it was running out of steam around 5400RPM. There is also a touch better initial tip in. They say only 8-12RWHP.
    I had to use an overdrive pulley (smaller than stock) to the alternator that VV8 was kind enough to help me with so that I could keep full charge all the time.
    Also, I tried and took it to 2 different places to get that damned original pulley off. It is on there with something lie 270LB/ft of torque. Absolutly unreal.
    I think it was worth it, though.
    Because It Must Be Brent!
    2003 Victory Red Silverado SS
    14.64 @ 91.78 on a 2.16 60' time even with my big frame driving! (5445lbs)
    MODS:
    Nelson Performance Tuned / TransGo shift Kit w/ Corvette Servos / ASP Under Drive Pulleys / Flex-Lite E-Fans / FlowMaster HD Trucker / Thermo-Tec wrapped manifolds to X-pipe / 1.5" dropped using Belltech 6400 kit & 6.5 turns on torsion bars / Tinted Windows / Victory Red Spray in Bedliner / Drk Walnut Wood (steering wheel, console, and door inserts.)
