Results 1 to 8 of 8
Thread: Vic Jr Pics
    casey23 Guest
    Vic Jr Pics
    I worked on the only thing I have right now getting things All clean mounted and All Bagged up now waiting on an Engine....
    Jul 2007
    Cedar Park,TX
    Finally dropped the coin on the TB I see. Looks SWEET!!
    01' 2500HD 4X4
    6.0L 4l80E
    stock....
    -Chris
    Jul 2007
    Colleyville, Tx
    thats the same setup i want to run..
    Looks killer!
    Cool, thats a 90mm right? Nick Williams? Intakeelbows.com elbow? What size injectors?
    casey23 Guest
    90mm Nick Williams,Intakeelbows.com elbow and 60lb Motrons I need to a few more fittings and -8an Line a few 90s and a Y Block ... Nothing 200.00 shouldnt fix .... I am still waiting on the 4l80 transbrake and Pan from Rossler I will take pics soon as i get it..
    Going to run a high rpm stall against it?
    ahhhhh looking so so familar , looking good!!!
    casey23 Guest
    10.5" 3 disc setup 3000.... No need for the High RPM stall... With the Brake i can leave the line around 800rpms more then Footbrake speed..and I really hope i can spool 6-8psi without a ton of trouble...
