Results 1 to 10 of 19
Thread: Low FRONT mount. give some feed back.
    Oct 2006
    Wichita Falls Tx.
    This kit will allow one to use the stock exhaust manifolds. Final turbo connection is still up to the end user. This is another option if you want a turbo kit but do not want the turbo in the engine bay. OR you like your rear mount and want faster spooling etc.
    The kit will have an oil pump. The turbo compressor housing is just slightly lower the the frame.
    You can see our air to air in one of the pics. We will have 3 options for our customers to choose.
    500max
    650+
    and 500+ALL day long air to water. Add ice or at the race track HP numbers go well over 750hp.
    Some prelim picks(mock ups) and as always getting peoples input.
    Online Store
    [/CENTER]
    Aug 2005
    St. Anthony, Indiana
    the filter looks really close to the front tire. It might suck in lots of water spray when raining.
    Jan 2006
    I like that setup, but would prefer to have the filter in the engine bay. Maybe a pipe running from the turbo up to the engine bay or somewhere that will not get wet with water. Make sure you don't use the oil pump that I had trouble with. They make on the Porsche that is a good pump, but its pricey.
    I like the concept.
    Jamest
    12 Sec. Club! SOLD
    SOLD***
    Oct 2006
    Wichita Falls Tx.
    Quote Originally Posted by foggy View Post
    yea that a down fall for any low mount turbo. The base kit will more then likely look like that, with an upgrade option for the filter relocation or sheilding.
    Quote Originally Posted by Jamest View Post
    I like the concept.
    Jamest
    Jamest, which pump did you have troubles with. This unit will need one for sure.
    Thanks
    Online Store
    [/CENTER]
    Jan 2006
    Quote Originally Posted by Turbo6.0L View Post
    Thanks
    I don't want to put down the other rear mount turbo guys, but their pumps. This is a place I was referred to that has different pumps:
    Gear Pumps AC/DC Oil / Fuel Transfer
    Hope this helps.
    12 Sec. Club! SOLD
    SOLD***
    Oct 2006
    Wichita Falls Tx.
    Hope this helps.
    yeppers helped a bunch, thanks
    Online Store
    [/CENTER]
    Jan 2006
    oops, I gave you the wrong websight. That was the replacement pump I ordered. Yes it is the same pump STS uses just a little cheaper as I was quoted.
    I 'll try and find the other websight
    Jamest
    12 Sec. Club! SOLD
    SOLD***
    Apr 2005
    The Woodlands, TX
    Hope this helps.
    Maybe I'm missing something here, but that is the EXACT pump that the STS kit uses. I had one on my truck for 2 1/2 years before I sold it and now it's on another truck and still running strong. I put 40+k miles on it.
    I dunno about that piping being lower than the frame rails. People that have lowered trucks might start getting a little scared with that setup. I know I wouldnt even be able to use it haha..
    San Antonio, TX
    The kit looks like it would work great! I bet it makes the same power as the current one. Actually, it's hard to mess up a turbo kit and not make power.
    From what I see on a regular basis, the pipe under the cross member might be too low, we get a lot of trucks that come in lowered and have a lot of scrapes on the crossmember.
    The filter is definitely going to get wet, that'll be an issue with the maf of course. Typical of any remote mount turbo.
    Did you conceal the feedline and return line that good or are they not installed?
    If not, those are going to hang a little bit too.
    Don't worry about the drain line being in the 6 o'clock position so it will drain correctly, mine drains just fine and you can see how horizontal it is.
