Trick build these custom units to fit in the upper corner passenger side on our trucks. But we can build many different type of tanks, locations. In the bed, or under the truck. Tanks are built from either Stainless Steel for water/meth, or Aluminum for fuel and water. Mounting brackets are usually welded directly to the tank.
Large filler lids on all tanks, etc, under the truck style. Those are completly sealed and have just inlet and outlet fittings. the tank in the pics is just under 2 gallons
Tanks start at 225.00 + freight.
This one fits in the bed and holds way over 12 gallons.
