Results 1 to 10 of 13
Thread: what gasket to use?
    what gasket to use?
    i just got my pacesetters and i need to know what gasket to use. i've heard some say stock GM gaskets is best but i don't know?
    2009 CHEVROLET 1500 with a MONSTER 4.8 between the frame rails!!
    Tuned by LSX Powersports ~ 4.10 ~ JBA Shorties ~ 4" Inlet/Outlet Spintech ~ Airaid Coldair
    CST 3.5" Spindles ~ Camburg Upper Control Arms ~ 2.5" CCM ~ FFR Tie Rods
    Full Throttle Suspension 3" Lift Blocks ~ Soft 8s wrapped in LT285/70/17 Silent Armors
    Oct 2005
    drinking your alcohol
    i re-used mine.... no problems at all
    DamnYankee: my nana failed
    Castro Valley, CA
    I bought some copper gaskets... its the only way to go
    2004 4.8l 6 speed manual 2wd
    Looks: 22" foose rims with Fierce tires, SS front bumper, SS Front Grill, 2/3 lowering kit.
    Performance: Volant Intake, 3" exaust with Spintech muffler, Pacesetter LT's with Y pipe, TR cam 220/220 .551 112 lsa, T56 Tranny with the Keisler short Shift kit and LS7 Clutch, Quicktime Scatter Shield, ASP Underdrive pulley kit, Dyno tune by Rick at Synergy Motorsports
    Soon to Come:Eaton locker, Electric Fans..Does it ever End?
    copper ? where at?
    May 2007
    Prairieville, La
    copper or stock is fine. just throw away the paper ones. victor reintz(spl?) also makes a stock style metal gasket
    Dec 2003
    Azle,TX
    Use new stockers...any auto supply will have em
    Vortec Performance Tuned
    well so far there is only one dealer around me that has them and orielly's and autozone have so special order them.
    Dec 2003
    Azle,TX
    its uasally the same day delivery.just reuse your old ones
    Aug 2006
    Willis, TX
    i reused my old ones..not a single leak
    05 RC, LME 6.0, 243 Heads, LSA Rods, 11:25 Forged Pistons, Cam Motion Custom Grind, 4:10, Eaton LSD, Narrowed Rear-end w/ Chromoly Axles, Pacesetters LT's, SLP Loudmouth II Mufflers, Volant CAI, Yank SSTB3600, Bosch 42 lbs inj's, G-Force Tune, FLT Level 4 Trany, Belltech 2/4, Times: ?
    Facebook
    The G spot in Gaskin, Florida
    What about re-using the head bolts?
    I heard you can't re-use the head bolts, but I would like to hear from someone who had swapped the gaskets.
    I am thinking BS
    2006 1500 CC/SB with the 5.3L and Nelson PCM.
    soon to come is a intake and exhaust. (wifes truck)
    Other vehicle is a 03 2500HD CC/SB 6.6L DMAX straight piped and Edge stacked with Superchips and gauges, Loves to eat rice for sure! Fartcan exhaust makes it better!
