Results 1 to 10 of 16
Thread: Engine transmission angle?
    How attentive should I be to this? The engine and tranny are in now and their at about 5-6* down towards the rearend. I also lowered the truck (4-6) and the rearend is 8-10* up towards the tranny. I don't have the cab or bed on the frame just to make it easier, but I didn't know if it would change these angles or not. Oh, did I mention the engine and tranny are in the frame
    Find you a truck in a parking lot somewhere and measure the angle of the pan and then duplicate it on your truck. Angle is important, supposedly. I don't know how important because rock crawlers run automatics and nearly stand them on the back bumper without issue.
    Aug 2006
    Willis, TX
    i don't think you're suposed to have no more than a 2* difference between the center line of the yokes. i may be wrong but it sounds like you have a deferential of 13*
    05 RC, LME 6.0, 243 Heads, LSA Rods, 11:25 Forged Pistons, Cam Motion Custom Grind, 4:10, Eaton LSD, Narrowed Rear-end w/ Chromoly Axles, Pacesetters LT's, SLP Loudmouth II Mufflers, Volant CAI, Yank SSTB3600, Bosch 42 lbs inj's, G-Force Tune, FLT Level 4 Trany, Belltech 2/4, Times: ?
    Facebook
    Mar 2007
    Carthage,TN
    Quote Originally Posted by racermech View Post
    Did you put any shims in between the leaf springs and axle to adjust ur pinion angle??? U will need to do that to keep ur pinion angle lined up right after 6"in drop in the rear
    00' 4.8l 5spd, K&N intake, Granatelli M/A, Shorty headers, Hypertech prg., 160* 2/4 drop
    yeah, driveshaft angle kills HP but when was the last time you saw the driveshaft angle on a severely lifted 4x4? Those things have scary driveline angles! They'll tilt the rear end to straighten out the pinion angle to the driveshaft but I wonder what happens when they no longer have oil on the bearings since the pinion angle is so pronounced.
    Mar 2007
    Carthage,TN
    I know it look like it would tear it all to pieces, there no way its good for them
    May 2004
    I'd set the pinion 3 degrees low to make sure there's no pinion to driveshaft interference. I leveled my motor and tranny out making adjustments to the crossmember and then set the rear drive shaft 3 degrees low. Trust me, if the pinion is too high it'll hit the driveshaft and knock the heads of the bolts off the pinion. Been there, done that! If you get a good bite on the pavement the pinion is going to the sky unless you have some ladder bars, Cal-tracs or a pinion stop. LOL
    97 GMC, 2002 LS6.
    1991 GMC Syclone #1428
    Jun 2007
    maine
    how exactly do you measure the * prolly something ill wana know for my swap since i have a 4/6 drop aswell
    Oct 2005
    Baton Rouge, LA
    Quote Originally Posted by Wtfan18 View Post
    I've done this by positioning the trans & pinion yokes such that the side of each yoke is parallel to the ground (to use somewhat of a flat surface). Placing the angle finder on the yokes will show you an angle measurement. Mine are within 1 degree of each other (4 & 5 degrees - trans & pinion respectively).
    One of the reasons for me asking this is because of the conflicting local information. As far as my rearend angle, I know that's off just by looking at it. But that's understandable due to the 6" drop. This link to s&p is what really got me thinking Driveline Angles . Also, I don't have the cab or bed attached right now, so that will change my engine tranny angle for sure... atleast a little bit. If it doesn't change enough, I was going to do what NITROUS spoke of and put shims/washers under the crossmember. BTW, thanks NITROUS for the help with that a/c idea, it came out great!
