Results 1 to 7 of 7
Thread: Fuel line question
    Fuel line question
    Will I need to change out the rubber fuel line in between the tank and the fuel filter or just the little piece in the tank? Thanks
    you should use approved injection hose if you are going to use fuel
    injection. the LSx uses pressure of 50-75psi. regular fuel line isnt
    rated for that kind of pressure. it might hold a bit, but can malfunction
    and usually at the wrong time.
    airdeano
    What Deano said. Get some good quality hose. I've noticed the new rubber fuel injection line is only rated to 50 psi. Be sure you buy some hose rated for the 75 psi that the stock pump can output.
    Thanks guys
    San Antonio, TX
    if you haven't gotten any, give us a call, we have some of that according style, stock hose, it's flexible and holds up great.
    ive found that dorman products make a plasic fuel line "repair" kit.
    has fittings, line, crimps, and more...
    im removing my -6an and replacing it with that kit. ive noticed the
    pressure line needs a shave. the pressure is pushing the rubber through
    the braided sheathing.
    airdeano
