Results 1 to 10 of 24
Thread: insturment cluster wiring
    Jun 2007
    tulsa, oklahoma
    i have a 04 4.8 in a 83 gmc p/u, I used the factory wiring harness and add a fuse and relay panel to it, I am trying to adapt a 02 gauge cluster to it, i have the factory manual for the 04 but none for the 02, was hoping someone could tell me what the 16 wires go to, which color to what, I have the speedometer, tach and amp gauge working, but not sure how to hook up the rest of the wires, thank you, this site has helped me a ton...
    1987 jeep wrangler, 1999 LS 1, 4l60 231j transfercase, dana 30 frontend ford 8.8 rearend 3:73 gear ratio. sandersons shortie headers, 2.25 inch exhaust into 3 inch flowmaster muffler.
    what computer/throttle system are you using?
    if using a cabled throttle body and 99-02 PCM you are good to go.
    if using a fly-by-wire (like in 03-07) then it wont work. the serial
    data the PCM supplies is "coded" differently.
    youll have turn signal indicators (2)
    low washer
    serial data (oil, water, optional trans temp and fuel) gauges
    12volt switched
    12 volt constant
    ground
    driver information center (4)
    speedo
    tach
    MIL
    thats all i know of...
    airdeano
    Jun 2007
    tulsa, oklahoma
    I am using the 04 pcm, vats removed, electric throtle body, need to know whick number and color wire goes to where thank you
    Jan 2005
    DFW, TX - Autobahn Volkswagen Tech
    I will look up the wiring diagram when I get home. I just put an '04 5.3 into my '01 silverado I just can't remember off the top of my head what all the wires go to.
    On a side note: Airdeano do you know if there is any way to change the serial data output on an '04 PCM so it will read on my '01 cluster?
    01 Silverado - 2004 5.3L Conversion from 4.3L V6 - Wheatley Tune - One Wheel Dance Off Champion
    http://shaggypokertables.com/images/sigblack.jpg
    NEED VW WORK OR PARTS? PM ME!
    Jun 2007
    tulsa, oklahoma
    thank you very much, will go out tomorrow and see what happens, i guess it probably willl not work since i have 04 pcm, but got cluster on ebay for .99 cents so got to at least try.
    Jun 2007
    tulsa, oklahoma
    thanks for wiring details, got the speedometer,tach, volt, oil, water, check engine light all working, now just have to figure out how to make fuel guage work, thanks again for info
    Sep 2006
    Lafayette, Indiana
    Quote Originally Posted by oldcarstulsa View Post
    How'd you get engine temp off of that pinout chart?
    2000 PSD F250 Super Duty Ext cab long bed 4x4 - a few mods...450+ HP 500+ lbs of torque!! (Daily Driver)
    1993 YJ "Buggy"
    1991 3/4 ton Suburban 6.2L turbodiesel
    Jun 2007
    tulsa, oklahoma
    it works off the serial data, only the oil pressure has its own wire
    Jan 2005
    This is from an '02 Silverado 1500 5.3L
    http://shaggypokertables.com/motorsw...terdiagram.jpg
    Jan 2005
    No problem, glad you got it working. Did you have to do anything special to get the 02 cluster gauges to work with the 04 PCM?
