can you take a cat converter off 03 4.8?
03 RCSB,4.10s,LTs,True Dual Magnaflows, CAI, EFILive, 10K HIDS
yes.. just need to get the rear 02's deleted in your tune or get 02 sims..if you dont you will have a service engine soon light..
Looking for a 05-07 Ext Cab or Crew Cab Chevy or GMC with some mods.. PM if you have anything
from what ive heard the truck will not even run right with them off. cause when i got my straight pipes i told them to take them off but he said it would not run right.
get a tune, then u can do almost anything u want with it.![]()
could i take the out w/ a superchips programmer or any other kind?
<div class='quotetop'>QUOTE(alabamachevy15 @ Apr 23 2007, 08:49 PM) [snapback]91126[/snapback]</div>could i take the out w/ a superchips programmer or any other kind?
No you need to have the o2 sensors deleted from your ecm, a "custom tune".
Allen Nelson is the shit from what i have been told.![]()
www.nelsonperformance.com
He deleted the cats from a buddy of mine's truck with a custom tune "2500hd6.0" and it runs like a scalded ape!!!
My Ride: 2006 Chevy Vortec Max, LQ9, 4X4, no cats, 50 Series Flowmaster in factory pipe, 20"s, C.A.I., Custom tune by Dustin at TRT Performance
you can only delete the rear o2 sensors from what i understand the first ( close to the engine) can not be deleted as the engine needs these 2 to run..
Simple: 408 on steroids!
single digits coming soon!
<div class='quotetop'>QUOTE(skeet @ Apr 23 2007, 09:49 PM) [snapback]91140[/snapback]</div>you can only delete the rear o2 sensors from what i understand the first ( close to the engine) can not be deleted as the engine needs these 2 to run..
[/b]That is correct, the front two help monitor the air/fuel mixture.
thanks for the info yall i will probally be looking into that.
yea whoever told you the truck wont run without cats is full of it.. just leave the front 02 sensors as is and let is roll..
