OK, the truck will be paid off within a few months. SO... I am getting ready for the LS1... once the truck is paid off it will be a matter of weeks as i get the stuff. Its a 1996 Reg Cab 1500 4.3 (orig. engine and tranny with 204k) incase you forgot. Heres the list I came up with off the top of my head:
- LS1 Engine itself w/ all accessories (low mileage probably around 00-01 model)
- 4l60E (should I build it up some??? what in particular should i focus on? just a side thought will a 4l80e bolt up? i know they are supposed to be a lot stronger. no t56 id like to keep it auto b/c it will be a daily driver.)
- new Driveshaft (tom woods??? what do you recommened? ive heard of woods d/s's busting though... ive heard the plates will need to be shortened also???)
- Radiator (what kind should I go with?)
- Harness (from dynatech of course)
- Motor mounts (from gmcwantsls1)
- Ignition setup (any good aftermarket you recommened? MSD maybe??)
- PCM tuning (from allen??)
- LS1 electric fans
- aftermkt intake?? airraid? k&n? what'll work?
- fuel pump? stock wont cut it right? will i need new fuel lines?
- VATS bypass (i dont even know what this is but im pretty sure ill need it)
other things i thought about:
corvette rail covers (the red ones that look cool)
true dual 50 series flowmasters (that might be too loud i wanna keep it a fairly quiet rumble)
tranny and oil cooler (is this needed?? they are just cheap enough, around $50, while everything is out do you think it would be worth it to put one in???)
rear gears?? (upgrade from stock?? is it needed? what is good for gas mileage?)
aftermkt thermostat???
plugs and wires??? (do you think recommened oem plugs are better or should i go with something aftermarket?)
escalade cluster (the one that goes to 120mph) - there is a guy on fullsizechevy who put one from a 99 i think in his 95 tahoe 383 and it works fine... any idea if there would be much rewiring going from my v6 cluster to a v8 or will the computer just send the right signal?
any good hi-amp alternators that'll work for the ls1?
a/c setup (doesnt allen make a bracket? how much? what if i skip the ac for now how do i take it out?)
OK! so... what else will i run into? What should i be prepared for? any more tips suggestions or ideas? i will be doing this myself (with the help of a friend who is a mechanic hopefully). Ill have access to a lift and all the tools i need so I think im all set. this is gonna be a daily driver, i want it to be fast, but gas mileage and reliablility come before a second at the track. any additional mods or things you would recommened? Alright then you guys have fun answering all my questions for the next few hoursThanks!!!
