hello guys- ive got a problem- i purchased a 68 shevy p/u with a 03 5.3 motor and trans from a tahoe- it is installed/runs drives/ problem is it bucks/backfires under load.. if i disconnect the o2 sensors it will run good??it pulls a code for the o2 sensors about them not going into heat cycle? im new to this engine and would appreciate any help. the wire harness is from squire performance< never heard of em. the computer is out of the same tahoe and was sent to some place in houston for a reflash/unused stuff removed. this is all i really know about it. thanks Lee
