what would be the benefit on going to the larger engine? how possible is it to upgrade the 4x4 parts to make it them hold up to the power? that would be a built engine not just stock, possibly 500 hp?
Man, about the best suggestion I could come up with if you're going with that much HP would be to go to a 4L80e tranny and tranfer case from a 3/4 - 1 ton 4wd. The transfer case has larger parts on the inside. You could buy a late model 4x4 drivetrain and put the whole thing in there. You'll have to figure out the electronic shift for the xfer case.
<div class='quotetop'>QUOTE(RedHeartbeat @ Feb 18 2007, 11:01 AM) [snapback]83699[/snapback]</div>sounds good thanks, i definately cant have parts snapping on me so i really need to overbuild the driveline.Man, about the best suggestion I could come up with if you're going with that much HP would be to go to a 4L80e tranny and tranfer case from a 3/4 - 1 ton 4wd. The transfer case has larger parts on the inside. You could buy a late model 4x4 drivetrain and put the whole thing in there. You'll have to figure out the electronic shift for the xfer case.
<div class='quotetop'>QUOTE(567234ta @ Feb 18 2007, 02:53 PM) [snapback]83712[/snapback]</div>4L80E/TH400i definately cant have parts snapping on me so i really need to overbuild the driveline.
NP205
Done.
Rich in N.C. - Just building your average '04 5.3L Vortec powered, 4-wheel steering, tubed, 4-linked, 42" tire shod, 2.5 ton military axle'd '73 Toyota Land Cruiser
Looking for an ignition coil for my 5.3.. Got one?
NP205 gear drive Tcase is indestructible, no doubt!![]()
well after reading the problems others have had with the 8.1 and just how few after market parts there are for it i am definately going 6.0
when you say 4L80E/TH400 &NP205 Done. what about axels or any other weak points? and rear end?
4150 u-joints and yokes will alleviate headaches in the driveshafts. put a good quality posi in the rear end and see if you can break it! The 8.5/8.6" rear ends are very strong, stronger than most guys would believe. If you have the G80 installed, replace it with a real LSD/posi before it falls apart on you.
<div class='quotetop'>QUOTE(RedHeartbeat @ Feb 19 2007, 10:30 AM) [snapback]83779[/snapback]</div>is it possible to not lock the rear end fully yet still have it durable? i didnt want to have problems turning from one wheel scuffing along.4150 u-joints and yokes will alleviate headaches in the driveshafts. put a good quality posi in the rear end and see if you can break it! The 8.5/8.6" rear ends are very strong, stronger than most guys would believe. If you have the G80 installed, replace it with a real LSD/posi before it falls apart on you.
Get you an Eaton posi or Auburn Tru-Trac and you will not have any problems. These will still allow the rear wheels to turn at different speeds when turning.
<div class='quotetop'>QUOTE(foggy @ Feb 19 2007, 10:02 PM) [snapback]83888[/snapback]</div>cool thanks for the info, i been saving my money and im almost ready to drive the truck to texas where im bringing it to nelson performance to get as much of the work done i can.Get you an Eaton posi or Auburn Tru-Trac and you will not have any problems. These will still allow the rear wheels to turn at different speeds when turning.
