Results 1 to 10 of 31
Thread: truck wont start
    Jun 2009
    Houston,TX
    Unhappy truck wont start
    when i turn on the key forward you can here the fuel pump come on, you turn it to start and it does for a second or so, and it dies again, it did that the other day and then it started to turn on and works great but today its doing the same thing that i wont turn on, so i connected the hp tuner and pulled this codes, hp tuners tech support said they were bcm codes and not to worry about it need some help. am not really worry about the brake codes but the others i don't know were start looking. thank you
    [Brake] C0236 - Rear Wheel Speed Signal Circuit Missing (History)
    [Brake] C0238 - Wheel Speed Mismatch (History)
    [Brake] C0226 - LF Wheel Speed Signal Missing (History)
    [Unknown] U1255 - Class 2 Communication Malfunction (History) (Immature)
    [Unknown] B2947 - Security System Sensor Power CKT Low (History) (Current) (Immature)
    [Unknown] B2958 - Security System Sensor Data Circuit High (History) (Immature)
    [Restraints] U1096 - Loss of Communications with IPC (History) (Current) (Immature)
    [Restraints] U1000 - Class 2 Communication Malfunction (History) (Immature)
    [Restraints] U1064 - Loss of Communications with DIM (History) (Immature)
    2000 gmc, 5.3, 220/224 comp cam,918 springs&harden push rods,long tubes,polish throttle body, 39lbs injectors,msd inline fuel pump,msd spark plug wires, 150shot, 3500 tci,servo,3.90w/eaton posi,m&h drag tires, tune by flaco,still need to re tune for fuel upgrade.
    check ecm fuse under hood/dash
    Jun 2009
    Houston,TX
    day 2 still wont start
    Quote Originally Posted by STUNNA View Post
    i checked all the fuses, before this happen my security light would stay on while i drove it, could that have something to do with it.
    Jun 2009
    Houston,TX
    Unhappy ignition switch
    one of my buddys said it can be the ignition switch, does anyone know how to troubleshoot for a bad ignition switch.
    Quote Originally Posted by 2000gmc View Post
    when i turn on the key forward you can here the fuel pump come on, you turn it to start and it does for a second or so, and it dies again . . .
    Hearing the fuel pump does not mean it's working properly. Put a pressure gauge on the fuel rail.
    Jun 2009
    Houston,TX
    Unhappy fuel pressure
    [QUOTE=Madd Maxx;346467]Hearing the fuel pump does not mean it's working properly. Put a pressure gauge on the fuel rail.[/QUOTE
    yes i have fuel pressure stock fuel pump plus msd booster pump.
    San Antonio, TX
    Have vats turned off.
    Jun 2009
    Houston,TX
    vats turned off
    what do you mean if i have vats turned off.
    Jul 2005
    Azle , Texas
    V.A.T.S. , vehicle anti-theft system , is it turned off in the tune ?
    Now what is a tune again?
    Comp Cam 54-412-11 , Int:265, 212, .522 , Exh: 271, 218, .529 , LSA 114 , Longtube , CAI (Vararam) , TransGo HD2 shift kit , tuned by me with EFILive
    Jun 2009
    Houston,TX
    Quote Originally Posted by Chevy366 View Post
    no i think it says serial. on the space.if i put it on none will it turn it off.
