Have vats turned off.
Nelson Performance
FastestTruckList.com
NP on Facebook
Youtube Channel
2000 gmc, 5.3, 220/224 comp cam,918 springs&harden push rods,long tubes,polish throttle body, 39lbs injectors,msd inline fuel pump,msd spark plug wires, 150shot, 3500 tci,servo,3.90w/eaton posi,m&h drag tires, tune by flaco,still need to re tune for fuel upgrade.
so i checked the fuel pressure and it is between 50psi and 60psi, checked sparked and there is spark on both banks, checked every fuse and none of the are blow. what else can it be, is there anyway to troubleshoot a bad pcm.
