Page 4 of 8 FirstFirst ... 2 3 4 5 6 ... LastLast
Results 31 to 40 of 78
Thread: Engine and trans are in
  1. #31
    Mar 2005
    Atlanta, GA
    Not much of an update, but I just have to mount the fuse block, Hook up the wires to the speedo, power, ign. and grounds; as well as swap fuel pumps and figure out the fuel plumbing. Radiator is mounted temporarily until I can find out a better way.
    Edit: I also got a cam,
    DUR @ .004" 272*/280*
    DUR @ .050" 210*/218*
    LIFT .551 / .551
    OVERLAP 52*
    LSA 112*
    I wonder what this thing will run in the 1/4 when I get finished?
    1991 c1500. 5.3l and 4l60e swap in progress, next paint and body.
  2. #32
    Jun 2007
    maine
    sweet!!
    Heck yah im a lil ways behind you but should be fun when they are done i got my motor and tranny out now its time to start ordering parts... cant wait blah... How has the wiring been pretty simple?
  3. #33
    May 2003
    Wichita,KS aka DOODAH
    Quote Originally Posted by Wtfan18 View Post
    The wirring is surprsingly simple, alot simpler than I had imagined.
    Get you a set of factory service manuals and it will go pretty easy for you.
    1990 SWB 2000 5.3l 4l60e
    It's in just tieing up the loose ends.
  4. #34
    Mar 2005
    Atlanta, GA
    Yeah, The wiring is the easy part.
  5. #35
    Quote Originally Posted by brian1987 View Post
    i looked at my wiring yesterday how was it the "easy part" lol
    it looked like a head ache.
  6. #36
    Jun 2007
    maine
    well i guess from what ive heard its 4 wires... where about do this splice in? i meant to ask will i be removing my old harness from the firewall and attaching the nelson one?
  7. #37
    i looked at my harness today its already set up on the motor i just have to plug it into the computer and mount a fuse box for the drive by wire TB, also mount the module for it.
  8. #38
    Mar 2005
    Atlanta, GA
    I haven't hooked up the 4 wires yet. With the old harness, I am hooking up the new harness, and leaving the old one until everthing else is done, then I will remove the parts I don't need.
    Quote Originally Posted by ChevyLee View Post
    Yeah man, I saw your engine and trans. it's super clean.
  9. #39
    Jun 2007
    maine
    now as far as the old harness goes will there be any plugs that you really even need? i guess i just need to have my damn harness done so i can see for myself. im trying to buy myself a crotch rocket at the same time since its winter people need heating oil bad haha. i can understand that one you hook up the 5.3 harness there will be the fuse block and there will be the 4 wires that will connect somewheres i was just trying to imagine what will be left of the old wiring harness that would be in the actual engine bay. when you get a chance throw some pics up! im a visual learner
  10. #40
    Mar 2005
    Atlanta, GA
    The four wires you have to connect on the harness from Nelson, I believe, are 12v constant, fuel pump, tach, and speedo .
    Maybe check with Red to be sure I haven't forgot anything as I am still learning as I go.
