always remember that the vats only cuts of the fuel, it wont keep the starter from turning over, thats a common problem that pepole think. if the starter wont ever turn over its not the vats system.
38" swampers, 350 tbi, 14 bolt rear, 10 bolt front
<div class='quotetop'>QUOTE(hummertech @ Aug 26 2006, 03:36 PM) [snapback]62492[/snapback]</div>That's why I replied back to my post. I thought it was turning over but wouldn't start.always remember that the vats only cuts of the fuel, it wont keep the starter from turning over, thats a common problem that pepole think. if the starter wont ever turn over its not the vats system.
97 GMC, 2002 LS6.
1991 GMC Syclone #1428
Obviously, you have underestimated my laziness. Remember, I write checks, not turn wrenches. I leave that to the pros. Last I heard it was turning over, just wont keep idle (this morning). Now, I believe he has run into the VATS problem.
2013 2wd Z71 6.2 crew cab
Old Truck: '04 Chevy crew cab stroked/bored 6.0 to 408ci. forged internals, patriot 68cc stage 3 heads (11.1:1cr), comp 244/246 .600 115lsa cam, 3000 yank tc, built 4L60E, walbro 255, 60# mototron injectors, pacesetter lt's 4" single no-cat exhaust
best time 12.93 1/4 mi @ 103 in the turbo truck.
1968 Camaro Convertible, super sweet!
Looks like I need a site that can host html files cause I can't save the wiring diagrams as anything else. I'll see if it will work as an attachment. Here is the 99 starting schematic, if it works I'll post the 2001. If not I'll need to email you the files. [attachmentid=589]
1965 C-10 shortbed stepside, 2003 5.3/4L60E conversion. Power steering, tilt wheel, power front disc brakes, 3.73 one wheel peel, 2.5/4 inch drop, relocated fuel tank and battery, 2002 Silverado buckets and console. Swap Pics
1968 Camaro 95LT1/4L60E lots o' mods Web Page
1961 Corvette project.......... C-4 suspension and brakes, 02 LS1/T-56 awaiting installation Pics
<div class='quotetop'>QUOTE(stssilverado @ Aug 26 2006, 08:20 PM) [snapback]62521[/snapback]</div>Obviously, you have underestimated my laziness. Remember, I write checks, not turn wrenches. I leave that to the pros. Last I heard it was turning over, just wont keep idle (this morning). Now, I believe he has run into the VATS problem.
97 GMC, 2002 LS6.
YES VATS is the problem now, anyone know how to turn these off, what all can be used to turn them off? The dude said exactly what brandon said its trying to start, but the VATS r workin too goodneed this guys can get truck back after this is resolved!!!
So, after spending all this time and money on a conversion you didn't get a PCM tuned by Allen? He can turn the VATS off while doing you a hotrod tune. They aren't as expensive as the full blown dyno/lifetime tune. Just get the lifetime tune and be done with it, you will be happily impressed just like the rest of us. If you don't want to do that, buy your own copy of HPTuner for your truck and do it yourself. You can always get one of those cheap other guys tunes but you'll get what you paid for.
<div class='quotetop'>QUOTE(RedHeartbeat @ Aug 27 2006, 04:03 PM) [snapback]62603[/snapback]</div>i cant spend that money this week i just wanna get the truck back, tune would be next, but other than spending $100 or more is there a way to turn the VATS off??????? i need this guys cant afford the tune right now, definetly without a doubt getting it later!So, after spending all this time and money on a conversion you didn't get a PCM tuned by Allen? He can turn the VATS off while doing you a hotrod tune. They aren't as expensive as the full blown dyno/lifetime tune. Just get the lifetime tune and be done with it, you will be happily impressed just like the rest of us. If you don't want to do that, buy your own copy of HPTuner for your truck and do it yourself. You can always get one of those cheap other guys tunes but you'll get what you paid for.
[/b]![]()
Do you know someone with HPT for your year model truck? They can turn it off for you. EFIlive, HPT, or LS1Edit can all do it.
I can only do 2000 6.0's with my HPTuners.
97 GMC, 2002 LS6.
