atta boy on your hard work. I bet that thing will run like a scalded dog! Get rid of that stock intake tube ASAP.![]()
Great job! I bet you love the way it runs!
97 GMC, 2002 LS6.
1991 GMC Syclone #1428
<div class='quotetop'>QUOTE(RedHeartbeat @ Apr 12 2006, 07:28 PM) [snapback]49973[/snapback]</div>Thanks for the comments everyone.Looks good plus you got me beat by 100 HP. What are you going to do for A/C? 2-80? 2 windows down and 80 mph?
I picked up an A/C Compressor from a '93 Bravada. We'll be fabbing up some brackets in the next week or two, but first I need to get the electric fans installed and a new intake setup as the A/C will interfere with the intake tube.
<div class='quotetop'>QUOTE(Tim Z @ Apr 12 2006, 08:06 PM) [snapback]49985[/snapback]</div>atta boy on your hard work. I bet that thing will run like a scalded dog! Get rid of that stock intake tube ASAP.
That intake tube was the only thing we could get to fit with the fan being so close to the motor. Once the efans are installed, I'll be making some sort of cold air box with nicer aluminum tubing to the throttle body.
<div class='quotetop'>QUOTE(GMCwantsLS1 @ Apr 12 2006, 06:53 PM) [snapback]49970[/snapback]</div>Yea, gotta take care of the green wire. Wasn't sure if we would be needing it for anything or not so we didnt tuck it into the rest of the wiring until we were sure.Nice job! I like the green wire wraped around the coolant overflow tank hose! J/K I bet it hauls!
The truck hauls for being a stock motor. Quite a bit faster than my friends stock Silverado SS, but a lot of that is because of the weight of the OBS and the tune on the LS2.
I bet that STS setup is fast.
Here's a pic of what the engine looked like before we started the swap
[attachmentid=526]
The truck it came out of obviously burned to the ground for the most part. I took an hour or two to completely wire wheel the motor with an angle grinder to a very nice polished look, put new valve covers on it, and a new front timing cover and that was it. Motor looked better than new when I was done with it.
Old: 1998 K1500 White ext cab stepside, vortec 350. Stock besides Volant intake.
New: 1998 K1500 with stock LS2 besides LQ9 truck intake and 8.1L Marine injectors. Dynotuned, 350rwhp, custom 3.5" exhaust, '02 F-Body Racetronix fuel pump setup. All wiring, exhaust, motor brackets done in shop.
holy shit that things fuuuuuucked up looks like brand new now compared to that picture lol
1999 GMC Sierra black reg cab short bed SLE Z71 5.3 <--CARDOMAIN PICS
NELSON 93 hot tune, 02 PCM, VOLANT Ram air intake, MSD wires, ACdelco iridium plugs , Edelbrock ceramic shorty headers, jegs off-road y pipe, Dynamax int pipe, 3" Magnaflow Exhaust with turndown, EGR removal, throttle body bypass, vette servo, long servo pin, performance 4th apply piston, B&M shift kit, SLP 160* thermostat, LS1 Fans, NELSON harness, ported and polished throttle body (did it myself, for free lol)..... _______? cam is next as soon as i stop spending all my money
Wow what a restoration on that burned up engine. The STS works great with a best so far of 12.7 @ 105MPH. It has been retuned since then and will see some track time as well as a 6 hour drive this friday.
damn, that was probably an awesome deal on a torched engine.
Holy BBQ Batman! Excellent work on bringing that crispy critter back to life!![]()
1965 C-10 shortbed stepside, 2003 5.3/4L60E conversion. Power steering, tilt wheel, power front disc brakes, 3.73 one wheel peel, 2.5/4 inch drop, relocated fuel tank and battery, 2002 Silverado buckets and console. Swap Pics
1968 Camaro 95LT1/4L60E lots o' mods Web Page
1961 Corvette project.......... C-4 suspension and brakes, 02 LS1/T-56 awaiting installation Pics
<div class='quotetop'>QUOTE(RedHeartbeat @ Apr 13 2006, 08:48 AM) [snapback]50025[/snapback]</div>damn, that was probably an awesome deal on a torched engine.
Picked up the engine for $1800. Unknown mileage, but its from a 2005 SSR so I'm guessing very low mileage. The junkyard has had the car for awhile also. We checked out the internals before we put it in the truck, and it looked brand new inside. I'm guessing less than 5,000 miles on the motor. At the very max, 10,000 miles.
I was very surprised at how clean the motor came.
Wow, they started putting the LS2 in the SSR? Last I heard they were sticking with the aluminum 5.3L.
<div class='quotetop'>QUOTE(RedHeartbeat @ Apr 13 2006, 07:58 PM) [snapback]50051[/snapback]</div>Yea, the '05 and '06 SSRs got the LS2 and option of a 6 speed manual.Wow, they started putting the LS2 in the SSR? Last I heard they were sticking with the aluminum 5.3L.
