Results 11 to 20 of 23
Thread: Strange problem after conversion?
  1. #11
    I have a copy of LS1Edit on my PC that I can look at it with if you send it here. Allen may still be able to look if he hasn't trashed his software. Is your MAP sensor connected? Is the brake booster hole connected? Is the IAC circuit functioning properly? Maybe it's just huge air mixture problems.
  2. #12
    Originally posted by RedHeartbeat@Oct 31 2005, 09:33 PM
    I have a copy of LS1Edit on my PC that I can look at it with if you send it here. Allen may still be able to look if he hasn't trashed his software. Is you MAP sensor connected? Is the brake booster hole connected? Is the IAC circuit functioning properly? Maybe it's just huge air mixture problems.
    Wont allow me to attach file?? Used the browse and found the file I have stored but comes back with message "can not attach that file type"
    .. The IAC appears to be working OK, Brake Booster hose plugged in with one way valve and is working correct. Map Sensor connected and according to AutoXray (Only tool I have to look at live/running @ idle data ) the map sensor is reporting in at "18in"Vac.. Will try loading file again... Roger
  3. #13
    If you have the original email that he sent you can forward it to redheartbeat@gmail.com and I'll look at it.
  4. #14
    Sent,,,, BIG THANKS!!! Roger
  5. #15
    C:\LS1Edit Files\rsweet.LS1
    GMC TruckBroadcast Code ID = 0411
    This is a 2001 GMC TruckLQ4 6.0 Liter PCM, that you didn't license
    This is the error message I get when I try to open it. I don't have an unlimited license. Allen may have to look at it for you. Odd that its a 2001 LQ4 tune though. He may have a few minutes to peek into it if you can fwd the email to him. I believe his addy is allen@nelsonperformance.com
  6. #16
    Redheartbeat.. not sure what you mean when you say license? The place that I had do the custom tune is a Place called PCMFORLESS. I am not sure what his process was/is for programing/ license. Thanks for looking (attempting) to look at information. I sent it to Allen also..
    Roger
  7. #17
    San Antonio, TX
    Send it on over!
    I'll take a look at it. However, I have seen pcms look just fine and not work correctly. It's some kind of magic.
    Even after a new flash with the genisys or ease controller, they still may be flaky.
    later,
    allen
  8. #18
    When an individual buys a copy of the LS1Edit software we purchase the right to program 1 to 4 pcms with specific VIN numbers. When a tuner purchases an unlimited license they purchase the rights to program unlimited PCMs. The tuner license is so much more expensive than an individual license. My software is licensed to two PCMs I owned. Some theiving bastards stole my truck a few months back and got my company laptop and LS1Edit software/hardware as a bonus accessory.
  9. #19
    San Antonio, TX
    I can't really see anything wrong with it. Like I said, I've seen weird things happen with pcms.
    allen
  10. #20
    Wow,, Redheartbeat,, Sorry to hear about you truck and laptop,,, dam that hurts to even think about it...
    That makes sense now in regards to the license information.
    You guys are amazing with the responses Quick wealth of info....
