Page 2 of 2 FirstFirst 1 2
Results 11 to 12 of 12
Thread: 1980 k10 lq4/4l80e
  1. #11
    Quote Originally Posted by Zaridar View Post
    Any thoughts on this T case? It's got u joint yoke rear. My previous 205 has slip yoke. As does my rear shaft... Should/ can I just swap tail shafts on t cases and use current driveshaft or look for slip yoke eliminator type dtiveshaft?
    Swapped rear output shafts no problem. Now my stock driveshafts will work
  2. #12
    Anyone use a signal generator adapter for speedometer? Speartech says it's a 4K pulse I was looking at the Dakota Digital one but it says 8k...
    http://www.dakotadigital.com/index.c...916/prd916.htm
    Apparently this puts out the exact signal the ECM uses.. PRF60116.
    https://m.summitracing.com/parts/prf-60116
    Then just have ecm flashed for any gears and tire size changes
