Page 2 of 2 FirstFirst 1 2
Results 11 to 19 of 19
Thread: 95 v6 swap questions
    Quote Originally Posted by Maverick View Post
    Thanks for the info, and sounds like its comming along quite nicely what schocks did you use becase im looking for some for mine as well I have a 3/6in. Drop
    Belltech nitros
    Aug 2013
    Alrighty thanks
    Sep 2012
    Quakertown, Pa.
    Here's a pic of typical plates. There are many out there, depending on what you want to spend. These plates are used in conjunction with the original "clamshell" mounts from the small block. I'm not sure if your V-6 was equipped with them, but I believe the mounting bolt pattern was the same on either the V-6 or V-8.
    I have read here on this site that the plates will need to be clearanced a little to clear a mounting boss cast into the LS engine block. Nothing a grinder can't take care of.
    http://www.ebay.com/itm/Trans-Dapt-4...e9233a&vxp=mtr
    http://www.ebay.com/itm/LS-engine-sw...517878&vxp=mtr
    http://www.ebay.com/itm/LS-LSX-Engin...5762d3&vxp=mtr
    John
    Aug 2013
    Quote Originally Posted by Mickeymotormount View Post
    Thanks I orders the motor mounts if they don't work or if I don't like them ill just swap the clamshells to the v8
    Aug 2013
    What do I do with the two pink wires from the blue pcm connector ?( making my own standalone harness already have fuse box in and OBD2 connector)
    Aug 2013
    how did you wire the a/c ? And the pink 12v positive that comes from the blue pcm connector what do I do with it I'm a little lost lol
    Aug 2013
    I found a walbro 255 inline fuel pump woukd that work to the 5.3 specs?
    Aug 2013
    Will my v6 obs starter work on the vortec ?
    Won't work. Have to use one that the LS motor uses.
