that i dont know how can i find out besides sending it back to the tuner
call the tuner and see what VIN tune he loaded or find someone with a tuner package to download the tune and read the VIN.
so if it was programmed for a 80e that would cause the engine to stall when put into gear
can a genesis scan tool download the vin
Not sure. HPTuner, EFILive, ...
so let me get this straight if the tune is for a 80e the engine will stall when put into gear
You will get SES codes related to the trans. 60e brown and white wires are different than on the 80e. The 3-2 shift solenoid wire hooks up to the TCC solenoid when wired wrong and will lock the converter in 1st gear, killing the engine, if I am reading the wiring correctly.
Try disconnecting the trans connector and see what happens, should work fine but start in drive without the electrical signals. If that is the case then you have the wrong tune or wiring harness. If it still dies you may have a locked up transmission or a bad convertor.
is it possible to repin the connector for a 4l80e and see if that solves the problem
try disconnecting it first and see if the engine still dies
