Page 2 of 6 FirstFirst 1 2 3 4 ... LastLast
Results 11 to 20 of 60
Thread: 06 4.8 sts turbo install advice(newbie)
  1. #11
    I didn't get one with my kit, I think allen just had one for me.
    Oct 2009
    Katy ,Texas
    know its a long shot but do you know any good local houston shops that might have what i need?
    06 silverado crew cab 4.8L
    STS Kit W/turbonetics BB 60-1 .81AR T4 and intercooler 10psi
    Nelson custom tune
    built 4L60E-hopefully it lasts
    2500 stall-Hughes converters
    42LB injectors
    3.5 Magnaflow exhuast
    6inch lift on 35x12.50s
  3. #13
    You can check PSI motor sports. I know there are a handful of other performance shops there, that city is huge lol
    Oct 2009
    Katy ,Texas
    ill give them a shot, do you know of any other method for oil feed to turbo?how about tapping a T fitting into the oem lines or something?
    Nelson custom tune
    42LB injectors
  5. #15
    Plainfield, IL
    I would GUESS you can order a factory oil cooler line from an HD or something, that would come with the plate/line you need. Then just route the line to the turbo instead of to the radiator...
  6. #16
    San Antonio, TX
    Just remove the flange above the oil filter and buy a 1/8" to -3an (jic) 45deg fitting.
    Also, with your setup and power you're looking for, get a Transgo Shiftkit and vette servo, mine live for a long time with 5psi.
    As soon as I turned it up to 10psi, the output shaft broke.
  7. #17
    Oct 2009
    Katy ,Texas
    yep were pretty much done with the install. we did remove the flange and tap it with a npt fitting and worked great. only things we have left is the booster T fitting, a few hoses. and need to buy about 3 ft of pipping.
    one question since my kit does not have the buzzer for the oil pump, can i run the two wires for the pressure switch on the oil pump to a light or something to tell me if it fails?
    Nelson custom tune
    42LB injectors
  8. #18
    Aug 2005
    St. Anthony, Indiana
    Anything less than 10 psi is boring. with that in mind, get you a built tranny with the billit input and output shafts. Get you a good posi unit in the rear end.
    60# injectors. You will also want an sd tune, because when it rains it will suck up moisture, when your in boost. Once the maf gets wet it will run rough until it drys out.
  9. #19
    Oct 2009
    Katy ,Texas
    got it installed runs great but is smoking . (burning oil) what could cause this, oil pump is running but very noisy. and it is ppushing oil back into the motor. any help is appreciated
    Nelson custom tune
    42LB injectors
  10. #20
    The Garage
    If your oil pump is really noisy, it's a good bet it is on it's last leg. I spoke to the STS tech guy and he said the oil pump will be noisy when it's about to go. Check the tailpipe for oil. If you find any, there will be oil in the intake pipes as well. This pump was recommended to me as a replacement.
    Exa-Pump®
    Check your intake pipes for oil. If there is any, it will cause the MAF to read less air. If you get it early, you can clean it and it will still work fine. Happened to me
