Page 2 of 2 FirstFirst 1 2
Results 11 to 19 of 19
Thread: Low FRONT mount. give some feed back.
  1. #11
    Oct 2006
    Wichita Falls Tx.
    Quote Originally Posted by trtturbo View Post
    I want one Rick. I just need to get the 6.0 in my '04.
    sweet lets get it rolling.
    Online Store
    [/CENTER]
  2. #12
    Oct 2006
    Wichita Falls Tx.
    Quote Originally Posted by Jamest View Post
    I don't want to put down the other rear mount turbo guys, but their pumps. This is a place I was referred to that has different pumps:
    Gear Pumps AC/DC Oil / Fuel Transfer
    Hope this helps.
    yeppers helped a bunch, thanks
    Online Store
    [/CENTER]
  3. #13
    Oct 2006
    Wichita Falls Tx.
    bump
    Online Store
    [/CENTER]
  4. #14
    Dec 2003
    Newark, Tx.
    not sure why everyone is down on the pumps sts uses. I have installed countless kits and have only had 2 fail.
    Some of these have been on over 3 years.
  5. #15
    Oct 2006
    Wichita Falls Tx.
    The first beta set up will be using an STS pump I picked up about a year ago. LOL.
    After that who knows.
    I will be putting together a bad ass deal on some sets once we have all things ready to go.
    KIT + IC for XXXX.00
    Online Store
    [/CENTER]
  6. #16
    Apr 2005
    The Woodlands, TX
    Hope this helps.
    Maybe I'm missing something here, but that is the EXACT pump that the STS kit uses. I had one on my truck for 2 1/2 years before I sold it and now it's on another truck and still running strong. I put 40+k miles on it.
  7. #17
    Jan 2006
    Quote Originally Posted by Turbo6.0L View Post
    oops, I gave you the wrong websight. That was the replacement pump I ordered. Yes it is the same pump STS uses just a little cheaper as I was quoted.
    I 'll try and find the other websight
    Jamest
    12 Sec. Club! SOLD
    SOLD***
  8. #18
    May 2005
    winchester va
    Have you found that pump
  9. #19
    Oct 2006
    Wichita Falls Tx.
    We have one we are going to use.
    Online Store
    [/CENTER]
