That's awesome, when you getting started on it, you'll love the power, the guy I just did this for is always calling and letting me know he's cleaning up the streets with his, lol, and it's only a peg leg without a built transOriginally posted by juztyn@Feb 1 2004, 11:33 PM
Just an update i am in the process of aquiring a few parts for the swap... going good. Just curious allen what is the general procedure for taking out the engine/tranny/driveshaft, etc., etc...? I will have a mechanic helping me but id just like to know. Thanks...![]()
Hope this helps:
-disconnect battery
-remove all that just attatching to the engine; air kit, wiring/harness, water hoses, etc.
-remove starter
-remove tc bolts
-remove bell housing bolts (it won't break apart, the engine and trans will stay together)
-support trans
-engine mounts
-remove intake
-remove steering shaft
-engine mounts, the long bolt side that is on the frame.
get you one of those adjustable engine remover thingys, you crank the long bolt and it tilts the engine for you , makes it a lot easier.
Those steps aren't necessarily in order, but it's a start.
good luck,
allen
