Page 10 of 15 FirstFirst ... 8 9 10 11 12 ... LastLast
Results 91 to 100 of 147
Thread: 1992 4X4 Blazer Build
  1. #91
    No leaks, I put two hose clamps on all connections. I use the smooth sided hose clamps, not the worm type. The type I use has a bolt that goes through it to tighten the hose.
  2. #92
    Sep 2011
    Atlanta Ga
    Quote Originally Posted by Minime168 View Post
    Got you a picture today. That's how it goes
    makes perfect sense now!!! awesome...so i need one more connector for the line going into the fuel line to the motor. so those connectors basically just snap onto the filter?
  3. #93
    May 2010
    Galveston, Tx
    Having a return on the intake just makes it so much simpler
    95 C1500 LM7, built 4L60e, Circle D 3200, LT's, Nelson tune, open differential, 3.42, and LS1 e-fans. Tractionless
  4. #94
    Aug 2011
    Galveston, Texas
    Quote Originally Posted by myzterray View Post
    Precisely. Push until it clicks. Kinda hard but make sure it clicks. And nah. I'd much rather only run one fuel line to the engine bay
    Btw autozone and all them stock the 3/8 push on connector.
  5. #95
    May 2010
    Galveston, Tx
    I don't have to run any line to the engine bay...it comes with 2 from the factory
  6. #96
    Aug 2011
    Galveston, Texas
    Quote Originally Posted by silverado_lover View Post
    Well true if you use the stock lines. Makes sense.
  7. #97
    Sep 2011
    Atlanta Ga
    hey since you converted to 2wd what did you remove from the front end? did u remove the front end differential? i want to remove the front differential from my truck..im thinking if i get some 2wd a arms, coils and spindles then drop the front diff and drive shaft if it will work? then later i can drop the transfer case swap the trans and drive shaft.
    heres the 2wd front suspension. only thing i dont see are shocks.
  8. #98
    May 2010
    Galveston, Tx
    The shocks go up through the middle of the coil spring
  9. #99
    Broken Bow, OK
    The 2wd a-arms won't interchange with the 4x4 ones.
    You could remove the front diff, but you have to leave the ends of the axles in the wheel bearing or they will collapse within driving a matter of feet.
    I have heard people say you can use the dished 5.3 flexplate with the spacer on the transmission side, but I've never tried it that way.
  10. #100
    Sep 2011
    Atlanta Ga
    Quote Originally Posted by PitchBlackC3 View Post
    yea i was just reading some stuff on fsc.com i guess the frame is different. now when i drop the front differential how do i know what exactly to leave? how much of the assembly should i remove. heres apic i found on fsc that kinda shows it.
    also when you say "transmission side" im not sure exactly what you mean.
