Originally Posted by
Blasphemy
I wouldn't run a boosted motor in a 4WD personally because you'll never be drag racing anybody at high rpms. If you want low end torque to move big tires and a heavy vehicle, I would definitely plan on getting the 6.0 but if don't mind doing the extra work of putting in a cam with a matched valve train, than a 5.3 could get you where you need to be. I have the LQ9 and its a huge amount of power over the 350 even in stock form. Running boost can be really pricey and ultimately shorten the life of an already reliable engine. If I put an LS2 cam, valve springs and intake on my engine (plus a beefy tune) I could get my hp numbers into the 400s
