why are you going carb? is it because your used to carbs and afraid of FI? if so, so was i. but after doing the swap and learning about fuel injection, its honestly the way to go. WAAAAYYY more benefits over carb... and if your motor is already set up for fuel injection, just run with it and learn it. especially since carbs are being "phased out" most especially if its a daily. if your an old school carb tuner/tinkerer for racing, then cool. but daily or new, just stick with the pcm. get a scanner and your life will be much simpler. just my two cents...
