Results 1 to 10 of 40
Thread: VSS issue in 6.0 swap in 94 4x4
    Just to make sure we're talking about the same thing, its the sensor in the middle of this picture? If so, it has a seperate harness and will need to be hooked up or you will not have 4wd. This wire engages your front axle actuator. By shifting the transfer case your engaging the driveshaft, but it will only free spin.
    Jun 2009
    Caledonia, MI
    Quote Originally Posted by slow94 View Post
    I am pretty sure that is it. It looks a tid bit different. My vss looks like its on the tail shaft of the tcase. Then the 4wd actuator plug ( or whatever you want to call it) is in the middle. I think we are on the right track. So keep the middle plug the way it is. Dont touch it, dont splice into it etcc.....?
    Silverado Z71 10" Lift COMPLETE 6.0/4L80E PRC 2.5 Ported LS6 Heads 228r Comp Cam 3200 CIRCLE D Stall LS7 Lifters ARP Bolts SLP Oil Pump and Double Timing Chain 160 T-Stat 3" SLP Loudmouth Electric Cutout Walbro 255 Pacesetter Longtubes MSD Starter NELSON Harmess NELSON Street/Strip Tuned ECM MSD Wires LS1 Throttle Body Braided Lines Spectre CAI 4.56 Gears Detroit Locker 14 bolt http://www.ls1truck.com/forums/lsx-t...wap-build.html
