Page 5 of 7 FirstFirst ... 3 4 5 6 7 LastLast
Results 41 to 50 of 62
Thread: Finally, my 1994 Silverado LSX swap thread!
  1. #41
    Nov 2011
    Stuart, FL
    Thanks guys. I am very impressed with the cam. It sounds great and it has a ton of power. It is not tuned yet and at 40mph I can put the truck sideways. I will get it dyno tuned in the next 2 to 3 weeks and will post up some numbers and a video.
    1994 Silverado 2 door sport side
    Soon to install:
    5.3 LM7, Thumpr Cam, LS6 lifters/springs, LS1 1.7 rockers, 862 heads milled 0.015 and 45 degree cut valves, LS2 timing set, Performer RPM intake, Holley 4150 750cfm carb, MSD 6LS ignition, 2" Primary LT headers 3" X-pipe and two Loudmouth II Mufflers. Vigilante 9.5" 2,800 Stall.
  2. #42
    what did you have to do to run the original alternator in the bracket? I have the stock obs one and the 5.3 one but am undecided on which to use. I would still like to keep my battery light if possible and use the old alternator.
  3. #43
    Sep 2012
    Quakertown, Pa.
    You can use the one from the 5.3 with the LS bracket. I used the LS bracket with the original 6.0 alternator with the one wire that goes to the battery light. Works great.
    John
  4. #44
    Nov 2011
    Stuart, FL
    It took some force but I managed to use the long bolt from the LS engine on the right bolt hole, and then threaded in the short original bolt on the left hole. It was pretty easy, just needed to use a pry bar to line it up just right. Some LS trucks used higher voltage alternators which use a different mounting pattern. I lucked out and had the same amp alternator.
    Soon to install:
  5. #45
    Mar 2013
    Long Beach California
    so are you saying a higher output alti is gonna be physiscally diff than a stck one? i thought they would be the same dimensinally just diff electrically... id def like to know the differences.
  6. #46
    Nov 2011
    Stuart, FL
    Quote Originally Posted by kewljay223 View Post
    When I went to Autozone they asked which amp alt. I needed. I was unsure so they showed me the pics of the alternators. The bigger amp ones had the 2 mounting holes in a completly different location.
    Soon to install:
  7. #47
    Nov 2011
    Stuart, FL
    http://www.autozone.com/autozone/par...4_670746_4443_
    Part Number: DL1532-6-7
    Weight: 11.05 lbs
    Warranty: Limited Lifetime
    Notes: 105 Amp alternatorWith 130mm (5 1/8") diameter alternator case. Premium Reman
    Alternator Diameter: 130
    Alternator Fan: External
    Alternator Mounting Brackets Included: Yes
    Alternator Output Amperage (A): 105
    Alternator Regulation: Integral
    Alternator Voltage: 12
    Automotive System Application: Electrical System
    Brushless Design: Yes
    Color / Finish: Same as OEM
    Housing Material: Aluminum
    Installation Hardware Included: Yes
    Package Contents: Alternator, Technical Troubleshooting Guide, Technical Support Sticker
    Product Condition: Remanufactured
    Pulleys Included: 1
    Vehicle System Voltage: 12V
    http://www.autozone.com/autozone/par...12_23521_4681_
    Part Number: DL1475-6-1
    Weight: 14.1 lbs
    Notes: 124 Amp alternatorPremium reman
    Alternator Diameter: 144
    Alternator Output Amperage (A): 124
    Pulleys Included: 1
    Soon to install:
  8. #48
    Mar 2013
    wow. good info man. i never thought they would be diff like that. i always figured you could upgrade your alti and it would fit. so this means you have to actually change the bracket n everything.
    does the higher amp one come stock on a diff truck like an hd model or similar? its got to fit something... they wouldnt just change the design out of nowhere and say "here ya go...good luck mounting it.."
  9. #49
    Sep 2012
    Quakertown, Pa.
    I have the higher amp alternator on my 6.0. It came with one so I'm not sure if the mounting bracket is the same as ones used on the lighter amp alternators. I thought the brackets were all the same.
    John
  10. #50
    Nov 2011
    Stuart, FL
    Just an FYI, these alternators that I have listed are for the 1994 model. I used my original alternator instead of adapting a newer one.
    Soon to install:
