Page 2 of 7 FirstFirst 1 2 3 4 ... LastLast
Results 11 to 20 of 62
Thread: Finally, my 1994 Silverado LSX swap thread!
  1. #11
    Jun 2009
    Youngsville, LA
    It's looking good. Good job on the clean up.
    2011 Chevy crew cab 5.3
    2013 Chevy crew cab 5.3
  2. #12
    Feb 2011
    Sevierville, TN
    Looking good!
    I used a rotary scuff pad to clean the pistons in my LS1. I also use laquer thinner to clean parts. It cuts through grease pretty quick, and dries clean.
    Matt
    Thanks to all American soldiers for their service and sacrifices.
  3. #13
    Just curious why you're going with the thumper cam? There are plenty more desireable cams out there.
  4. #14
    Nov 2011
    Stuart, FL
    For the accessories I poured 2 gallons of mineral spirits in a large plastic container and scrubbed them with steel wool and a wire brush. For the block and pistons I used a wire attachment on my drill and mineral spirits in a spray bottle.
  5. #15
    Nov 2011
    Stuart, FL
    Well there are a few reasons:
    1. It can be used with the stock stall and gears
    2. I already had LS6 springs which are perfect for the lift
    3. It has a good rpm range for my application
    4. It sounds freakin great
    5. It works great for carb applications
    6. It makes peak HP around 4500 rpm and tq at 6000. I dont want to go over 6000 rpm due to the stock rods and bolts
  6. #16
    Nov 2011
    Stuart, FL
    Got the Harmonic balancer off today, that thing was shot. Going to try to take off the oil pan tonight and maybe paint the block tomorrow.
  7. #17
    What makes you think stock rods and bolts will fail at 6000rpm? I shift my truck at 6200 with a completely stock 260k mile bottom end. I know plenty of people pushing past 6000rpm with no issues.
  8. #18
    Nov 2011
    Stuart, FL
    I think it can do just fine but why risk it. The two most common reasons an engine fails is from high RPM and detonation. I want this bottom end to last at least a year so I can build an LS1 or 6.0 short block.
  9. #19
    Arizona/Utah
    The thumper isnt the best LS cam and if you are looking for lope get a good tune.
  10. #20
    Nov 2011
    Stuart, FL
    Most of the people i have heard to complain about the thumpr had it with EFI. I will have it dyno'd when its done and we will see how the cam is.
    What i got done this weekend:
