Page 20 of 44 FirstFirst ... 10 18 19 20 21 22 30 ... LastLast
Results 191 to 200 of 436
Thread: my first ls swap 1996 2 door Tahoe 4wd 385 Stroker to LQ4 cam headers **pics**
  1. #191
    Sep 2011
    Atlanta Ga
    Did you get the transmission plugs all figured out?
    oh worked out cool..i transferred the plugs from the old harness to the new one. however on the neutral safety switch there are about 3 or 4 wires that dont connect to anything. ill take a pic tommorow but i know one is for vss but not sure about the other ones. Also i have a buddy who just put a 6.0 in an impala ss and he didnt use that plug on the driver side of the trans. not sure how tho..
  2. #192
    Sep 2011
    Atlanta Ga
    Quote Originally Posted by silverado_lover View Post
    What is that vacuum adapter fitting? I've never seen anyone mention that in their build thread
    this --------->
  3. #193
    Sep 2011
    Atlanta Ga
    so now i got the right motor mounts i was able to bolt up the drivetrain. ended up pulling the motor back out so i could modify the factor harness. also wired up the engine. my new harness doesnt have a plug for the knock sensor in the oil pan. is that bad? also i broke my timig cover when i trying to align the engine. and also a coil. if anyone has a coil and timing cover for sale please let me kno!
  4. #194
    Broken Bow, OK
    That sensor in the oil pan isn't a knock sensor it is for oil level. You don't need it.
  5. #195
    Sep 2011
    Atlanta Ga
    oh ok...question for ya...i was looking through http://lt1swap.com/1996_vortec_5.7/index.htm trying to figure out what wires i need to take from the old pcm and connect to the new one. so far this is what ive gathered.
    blk connector
    1 fuel pump.. connect this wire to the relay on the new harness
    4 vss output splice green wire from harness onto this so i have the signal for the new pcm and still have functional speedometer gauge
    5 connect to mil control on new harness for check engine light
    10 connect to tcc wire on harness
    blue connector
    10 tcc connect to tcc on harness
    then i believe all thats left would be the tach signal..not sure how to find that wire and im not sure which wore connects to the tcc.
    just looking at the schematics this is what i think i will have to do. correct me if im wrong.
  6. #196
    moving right along, looks good!!!! wish i could help you out on the wiring. i haven't got that far on mine yet & i'm running only the LS1 ECU. i still have to figure which wires to tie into for the speedo & tach.
  7. #197
    Sep 2011
    Atlanta Ga
    Quote Originally Posted by RPM Graphics View Post
    thanks man! its a slow steady project. yea i dont think it will be that difficult. im just checking with pitch black because he is very knowledgeable and has helped me out so much during this build. once i get everything working ill will definitely pass the info along.
  8. #198
    Broken Bow, OK
    For the speedo, you will need to use the output from the new PCM. Your 96 gauges need the PCM to translate the VSS signal into a usable signal based on gear ratios and tire size.
    The tach will use the output from the PCM as well. The tune can be adjusted to work with the 96 tach which is looking for a 8 cyl output rather than the 4 cyl output the 99-up gagues want to see.
    If your harness doesn't have PCM outputs for those 2 things, you will want to add them.
  9. #199
    Sep 2011
    Atlanta Ga
    ok cool...any idea what pin that would be from the harness? everything else was right?
  10. #200
    Aug 2011
    Galveston, Texas
    Swaps coming along well! Im loving mine man
    1992 Full size blazer 5.3 Swap successful.
    http://www.ls1truck.com/forums/lsx-t...zer-build.html
    Galveston, Texas
