Results 1 to 10 of 10
Thread: Tb to water pump clearance issues
    who happen to know what water pump i need with my ls3 intake swap...i cant run the car 90mm tb cause it hits the water pump..so im running the 87mm truck tb for now...i was looking at the ls3 w/p but heard it would need spacers and well the water neck is on the other side it may interfere with my belt...any ideas
    heres a pic,the truck tb barely fits...imagine the 90mm car tb with the ugly module on the side...i just wanted to get the 90mmtb on there before my retune
    Just curious, what is that water pump off of? Seems like my top hose comes straight up.
    Quote Originally Posted by emmerich5.3 View Post
    thats a oem 08+ water pump...im still looking into water pumps so i can run the 90mm tb....was at parts store earlier and looked up some pumps i mite try this one .i like the fact that it has a wide pulley
    That's what I was thinkin you needed. It's off an f-body and/or vette right?
    yea i just looked it up off a 98 vette ls1...
    Screw it just get an electric pump.
    F body pump will work !
    Simple: 408 on steroids!
    single digits coming soon!
    +1 the EWPs upper neck goes straight out in front..
    Sponsored by Taylor Wires!
    Sponsored by PowerMaster!!
    Sponsored by FROZEN BOOST!
    Sponsored by US Speedo!
    don't know about what water pump but i have seen a tb spacer that puts the part that houses the tb motor at 10:30 alleviating interference problems (if i recall it was on a vette forum)
