ive been after a low fuel pressure/ lean issue for a while now, i used to only have a about 38lbs of pressure at an idle, and then when the truck started making boost (magnacharger) my pressure would drop way down and the truck would run lean. so i upgraded to 60lb injectors, gutted out the stock sending unit and put a walbro 255 pump in the tank witch brings me to around 48 psi, then i disconnected the fuel pressure regulator and brought me around 52-54psi at an idle, but when i start making boost im almost down at 20psi, and the things kinda of slug. so im thinking i need to change my in line pump, im not sure witch pump it is its the one that comes from mangacharger, i just don't know what i should run for an inline pump to feed those injectors. any suggestions?
