ill have a long while to do it i have several th400 and th350s no newer trannys tho still have to get some more stuff for my motor swap
BlueL92 has a v6 truck, with a 6.2L and TH350 swap, pm him and ask him.
Nelson Performance
FastestTruckList.com
NP on Facebook
Youtube Channel
there are numerous options, crank spacer, longer bolts and flat flexplate, dished flexplate and spacer on the trans side of plate with longer bolts, dished plate with hughes convertor snout extension... with the dished flexplate you will need to slot the bolt holes to align with the old convertor bolt pattern or you have to drill new holes in the correct pattern. As has been reiterated, do the 80e and forego the headaches of multiple swaps and retrofits.
i understand about bolting them together was more courious on the electrical side of things
Nelson Performance
NP on Facebook
Youtube Channel
2014 Xsport- 3.5 Eco boost
412 Motorsports
thanx for all your help. like everything else its all about prefrance one person may like it the other might hate it
