lsxrt
I got one the day they were released from Thunder Racing. I bought the fuel rails thru FAST, although Thunder should have them as well. You will also need a fuel regulator, and associated fittings, hoses and hardware. The whole thing will run you over 1500. I used an LS7 90mm because it has the ETC I need on my Hummer. Otherwise, you can go bigger if you need to with a cable throttle. I thinks it looks good under the hood, and the engine performs great. I don't know what the difference is, since I did not use the old intake after I built the motor.lsxrt.jpg
2003 H2, 408 cubes, Dynatech headers, high flow cats, magnaflow exhaust, FAST LSXRT 102mm intake, Nelson Performance Tuning, Schneider racing cam (.552 lift, 266 dura.,114 lsa), K1 4.00 Stroker Crank and 6.125 con rods, .030 over Wiseco pistons,10.5 to 1 comp., FAST injectors, LS7 90mm TB, SA Gear Double Roller Timing set, Comp Cams Roller Rockers/push rods/studs, MSD Coils/plug wires, shift kit, Fabtech 6" lift, 37x12.5x20 Nitto Grapplers, JJ 20x9 Black Widows, E&G flares.
