Page 3 of 3 FirstFirst 1 2 3
Results 21 to 28 of 28
Thread: Lifter Noise
  1. #21
    Good to hear I was pritty sure that was your problem.
  2. #22
    Lancaster PA
    Quote Originally Posted by 6.0vortecchevy View Post
    Great advise! Nice job.
    04 GMC Regency - Building a 6.0 Comp 7.4" Hi-Tech Pushrods, Patriot Performance 8401 Spring Kit, Comp Double Roller Timing Chain, ARP Rod Bolts, ARP Head Bolts, Cam - I dont know yet, any suggestions???
    89 Chevy Cheyenne - 10/24/09 Time of death declaired at 8:16pm.
  3. #23
    Sep 2010
    Sorry to bring up an old thread, but I have a similar issue. Could this still be the case even with over 40lbs of oil pressure?
  4. #24
    At what rpm are you getting 40lbs. If idle then its not your oring.
  5. #25
    Sep 2010
    About 1500 - 2000. I'm going to check the lifter preload tomorrow.
  6. #26
    Sep 2010
    Lifter preload is way low. (.015)
    How is it so low with 7.4 rods and stock heads. Tr224 cam.
  7. #27
    Sep 2010
    Was actually an exhaust leak. But would only show up when driven hard. odd, but happy I found the problem.
  8. #28
    Most likely the heat expanding the metal and creating an air passage.
