Page 2 of 2 FirstFirst 1 2
Results 11 to 19 of 19
Thread: Causes of high idle and idle surge...?
  1. #11
    0507 is the tell tale.
  2. #12
    Mar 2006
    Mesquite
    ...how so?
  3. #13
    It's not easy to set and not common. The conditions are tight. Call me tomorrow and I'll look it up iffin you wanna...
    V has a good idea too to have L look at the chune.
  4. #14
    Mar 2006
    Mesquite
    I only understand half of what you typed.
  5. #15
    Poor Moze.
  6. #16
    Mar 2006
    Mesquite
    I understood all of that one.
  7. #17
    Jun 2009
    Dublin, Ga.
    get a can of starting fluid and spray around the intake and vac. lines. if it revs up high then you def have a vacuum leak and knnow where to start looking.
  8. #18
    Sounds like a technician to me. That's what the PC name is now.
  9. #19
    glendale,az
    what did you change or what happen,did it pop under a pass ?
    i have a 2001 chevy did a 4.8 swap to a 6.0l with mahle pistons 10.5:1,eagle 6.125' h beams,232 238@50.595 598 lift on a 112lsa,243 heads,44lbs motec IIs,tuned by Nick D,it makes 402rwhp,@5000lbs w/ me in it 13.75@101mph on 22' wheels
