Page 2 of 4 FirstFirst 1 2 3 4 LastLast
Results 11 to 20 of 35
Thread: New project
  1. #11
    Pittsburgh, PA
    if n budget drop a 4.8 in there and build the kit around this motor till you can afford a forged 370. I can tell you a 4.8 will hold a good bit of boost and ppl throw 4.8s away. so its a win win situation to start with
    2014 Xsport- 3.5 Eco boost
    412 Motorsports
  2. #12
    I second this. Boost does anything good.
  3. #13
    Jun 2004
    george west texas
    yes...370 with boost will make you smile and smile!!!!
    '13 silverado LT...stock
    '11 lt 4x4 z71..tvs1900
  4. #14
    ff_jeff Guest
    Ok, I think I will go the turbo route. But which route do y'all think? STS style would be cheaper right? But I have plenty of room up front for a front mount.
    Im liking the idea of a rear mount, But it seems that most people with a rear mount go front mount afterwards. I also have a limited budget.
  5. #15
    Front mount, but that truck needs a few things first.
    V8, and some traction!
  6. #16
    Pittsburgh, PA
    front mount is cheap!!! if you were closer to me id fab up you a kit
    412 Motorsports
  7. #17
    I still have a 370 Jeff... Drop that in, get everything setup for boost, when you can afford the turbo setup.. add the turbo system. Don't mess around with anything that is not needed!!! Get a plan and stick with it!! Wait to drop the truck until you or Jon Jon or myself come across a great deal on lowering parts. Keep the V6 in till everything on the motor is a go and make it a long weekend install. That's a nice truck and a great platform to start with!!
  8. #18
    Kurt's idea makes most sense to me....
  9. #19
    ff_jeff Guest
    Quote Originally Posted by DBTBSS View Post
    I still want to put in in. I guess I need a list of everything needed to put the 370 in.
  10. #20
    http://www.ls1truck.com/forums/lsx-t...onversion.html
    Complete engine with accessories
    4L60e/80e
    modified wiring harness or NP harness
    engine mount adapters
    v8 engine mount cups
    v8 engine mount rubber mounts for xmember
    Walbro pump
    fuel fittings and hose
    fuel filter
    Schoenfeld headers
    ypipe
    tune
